Hiện kết quả từ 1 tới 11 của 11
Chủ đề: cho em hỏi về sub alpine
    OFC-15988
    Được cảm ơn: 0 lần trong 0 bài
    em có cái sub alpine type R 15'', vậy cái ampli sau có đánh được em nó không
    Xenith Series Monoblock Class A/B Car Amplifier with Orange Chassis
    RMS Power Rating:
    4 ohms: 200 watts x 1 chan.
    2 ohms: 300 watts x 1 chan.
    Max power output: 600 watts x 1 chan.
    MOSFET high speed power supply
    LED power (green) and protect (red) indicators
    Selectable bass boost (0, +6dB, +12 dB)
    Soft start system with mute and delay features
    Mono channel operation
    Speaker-level (high-level) inputs with signal sensing for automatic turn-on
    Tiffany style RCA Jacks
    Preamp RCA outputs to daisy chain multiple amps
    4-Way System Protection circuitry
    Angled connection terminals
    Computer optimized heatsink design
    Bipolar studio-grade output stage transistors
    Heavy duty aluminum alloy heatsink for extreme heat dissipation
    Nickel-plated RCA level inputs
    Nickel-plated screw terminals
    Input sensitivity:
    Low level: 200mV-8V
    Variable low-pass filter (40-250 Hz)
    Damping factor: >100 @ 100 Hz
    Frequency response: 10-250 Hz
    Chassis color: Orange
    Chassis color also available in: Black
    Dimensions: 10-7/16"L x 10-1/2"W x 2-5/8"H
    8-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
    Authorized Internet Dealer
    1-year Manufacturer's warranty
    Note: Cadence has made an update to their line of Xa amplifiers. This new "H" series update has been redesigned for 30% better heat dissipation and they have added High Level OEM Integration Inputs and Tiffany Style Isolated RCA Jacks. Even though the amplifier is labeled as Xa300.1 you are indeed purchasing the new upgrade XaH300.1 amplifier. Please feel free to contact us regarding any concerns.
    Em cảm ơn các bác tư vấn giúp em
    href='member.php?u=15988'>ANDY1606 ]=-
  2. #2
    OFC-418
    Hanoi
    Được cảm ơn: 68 lần trong 28 bài
    Coi cái amplifier thì thấy công suất hơi nhỏ bác à, bác xem cái model của sub là gì để em check giúp bác em công suất bi nhiêu.
    - THIẾT BỊ ÂM THANH & PHỤ KIỆN ĐỘ XE - HOTLINE: 0989.09.0989
    ROCKFORD FOSGATE - MOREL - BLAUPUNKT - DLS - METRA - LIGHTNING AUDIO - EAGLE EYES
  3. #3
    OFC-15988
    dạ em thấy nó ghi là alpine type R 15'' SWR 1541D 4ohm+ 4ohm,nếu cái ampli trên hơi yếu thì đánh chừng được bao nhiu % CS ah thanks bác
  4. #4
    OFC-15988
    cứu em với.....................
  5. #5
    OFC-454
    Được cảm ơn: 885 lần trong 350 bài
    Hi bác,
    15" R type có power handling 200W-500W/(1500W peak). Dual voice coil có thể ghép serial, hoặc parallel để cho ra 8 Ohm hoặc 2 Ohm.
    Theo spec của Ampli, 200W và 300W là công suất RMS, tương ứng 400W và 600W max với 2 trường hợp tải là 4 Ohm và 2 Ohm (Amp này không có khả năng làm việc ở 1 Ohm)
    Vậy, bác có thể dùng ghép các cuộn dây của Sub thành 2 Ohm để kéo bằng amp này
    Tuy nhiên, em chỉ dựa vào thông tin bác cung cấp để tư vấn cho bác như vậy, chứ cũng chưa có trải nghiệm thực tế với amp này! Mặt khác, với giá tiền của amp, em nghĩ sẽ là rất khó để bắt em 15" Type R làm việc tốt nhất trong khả năng của nó!
    thay đổi nội dung bởi: CarAudio.Vn, 12-01-2012 lúc 09:21 AM
    ))) CAR AUDIO (((
    GARAGE PHILONG: C5/15 Đường số 6 Bình Hưng - Bình Chánh - Tp.HCM
    HanPham: 0906.234.111
  6. Thành viên đã gửi lời cảm ơn đến CarAudio.Vn về bài viết có ích này:
    Vita (12-01-2012)
  7. #6
    OFC-12
    Hochiminh - Vietnam
    Được cảm ơn: 5,573 lần trong 1,615 bài
    Bác ơi muốn phối ghép ampli và sù thì phải nghe thử ... bác đến gara đề nghị phối ghép cho nghe thử ... ngoài yếu tố kéo có nổi không thì ampli phải đáp ứng các tiếc tấu cần thì của bản nhạc nữa.
    0986 66 77 88
  8. #7
    OFC-15988
    dạ tại đồ tặng nên em đinh hỏi trước ok rồi em mới mang ra tiệm gắn,để khỏi mất công không được lại chở đi chở về
  9. #8
    OFC-15988
    Trích Nguyên văn bởi CarAudio.Vn Xem bài viết
    Hi bác,
    đoạn màu đỏ là sao em đọc mấy lần chưa hiểu
  10. #9
    OFC-12
    Hochiminh - Vietnam
    Tức là con Xenith Series Monoblock Class A/B Car Amplifier with Orange Chassis với giá tầm 100 usd thì mình khó bắt nó làm việc tốt hơn giá trị này đó bác.
    0986 66 77 88
  11. Thành viên đã gửi lời cảm ơn đến Vita về bài viết có ích này:
    CarAudio.Vn (15-01-2012)
  12. #10
    OFC-15988
    vậy tư vấn dùm em sub nào đánh ok cho em ampli trên dể khỏi bỏ phí ah thanhks các bác.
  13. #11
    OFC-15988
    không bác nào giúp em với
  1. Độ Focal Krx3 & PXA H-800 Alpine trên Volkswagen Scirocco
    By MinhKhoi in forum Âm Thanh & Nội Thất Xe Hơi
    Trả lời: 4
    Bài mới gửi: 28-08-2011, 01:04 PM
  2. Bán Loa amp solid 4 Focal K2P + DVD Alpine + Active Crossover Alpine PXA H701 hàng hiếm!!!!!
    By Amnesty in forum Xe Hơi, Linh Kiện Và Dịch Vụ Cho Xe Hơi
    Trả lời: 1
    Bài mới gửi: 09-05-2011, 11:47 AM
  3. Em bán 1 supwoofer xe hơi ALPINE SWE-1895
    By tranhongphuoc in forum Xe Hơi, Linh Kiện Và Dịch Vụ Cho Xe Hơi
    Bài mới gửi: 27-09-2010, 06:33 PM
  4. Bán Sub Alpine và Pioneer
    By pavilon in forum Xe Hơi, Linh Kiện Và Dịch Vụ Cho Xe Hơi
    Trả lời: 4
    Bài mới gửi: 04-08-2009, 11:27 AM
  5. Processor Alpine PXA-H100
    Trả lời: 2
    Bài mới gửi: 30-12-2008, 07:39 AM
